is it worth it? where is the best place to buy it? how much is it? im getting a system soon and im pretty sure im gonna have to get a cap or a high end alternator
spiral cell batteries are not even remotely the same as regular car starter batteries. Normal car batteries don't like to be discharged significantly and recharged again. A normal car battery is made for the car to take a tiny bit of juice while starting then the alternator kicks in and runs the car. If you're running a serious aftermarket stereo or like to sit with your radio on and car off, a deep cycle, or spiral cell is the only way to go. They can handle being discharged completley and recharged several thousand times, with a conventional battery every time you discharge it below a certain point(I believe 95% but don't quote me on that) depsits start to build up on the plates reducing the effective maximun charge of the battery, that means you're slowly killing it. I killed my stock battery in about 3 months because of my tiny stereo, I've since had an optima blue with no troubles at all. Out of the conventional batteries around, Honda makes some of the best there is, but they still won't hold up to the abuse some of us like to put them throughxdannyx25 said:just get a battery with atleast 100 cca over what the stats say for your car
I'll second you on that my friend. I know of a few guys running them and they are VERY pleased. I WILL BE running at least one in my next install (whenever hell freezes over, pigs fly, and I have enough money).illusion said:
Another thought if you're concerned about you electrical system because of a stereo is invest in a xstatic batcap, small, effective, and better than your average 1 farad cap.
take a peek.
http://www.batcap.net/Model300.html
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1385256703&rd=1
Honda doesn't make batteries. But i wouldn't get a battery unless you are gonna listen to your system with the car off. If you are worried about the electrical system not beibg able to keep up upgrade the wires under your hood, batt to ground eng to ground, then the alt.illusion said:Out of the conventional batteries around, Honda makes some of the best there is, but they still won't hold up to the abuse some of us like to put them through
[/url]
The one in my Teg was actually Panasonic. Do Accords have those too?litspliff420 said:i think hes reffering to the standard battery that comes with Honda. they might not make them, but they do have them made for their cars, and thats what he's saying.
illusion said:spiral cell batteries are not even remotely the same as regular car starter batteries. Normal car batteries don't like to be discharged significantly and recharged again. A normal car battery is made for the car to take a tiny bit of juice while starting then the alternator kicks in and runs the car. If you're running a serious aftermarket stereo or like to sit with your radio on and car off, a deep cycle, or spiral cell is the only way to go. They can handle being discharged completley and recharged several thousand times, with a conventional battery every time you discharge it below a certain point(I believe 95% but don't quote me on that) depsits start to build up on the plates reducing the effective maximun charge of the battery, that means you're slowly killing it. I killed my stock battery in about 3 months because of my tiny stereo, I've since had an optima blue with no troubles at all. Out of the conventional batteries around, Honda makes some of the best there is, but they still won't hold up to the abuse some of us like to put them through
take a peek.
actually, if your alternator goes out the battery with more cca will last longestGSteg said:also..a battery with more CCA won't last as long as a battery with less CCA. only use the higher CCA if you live in a very cold climate, or if you need the cranking amps to run 457493752+ amps in your compeition for for the local comps (not daily driven)
Ok first point, read what he said "I am getting a system soon" well the stock battery and alternator are a hinderance. The battery is the quickest and easiest to replace, but using a batcap you might not even have to replace it, just add a batcap with the amps and everything should be happy, unless you are pulling some serious current, then a full electrical system is in order.xdannyx25 said:i was in the influence that he wanted a better or stronger battery not another battery just for the stereo, dont really see why you would need this with a strong alternator unless this guy will have a trunk full of amps and wires
not true. The battery with the higher aH(amp hour) rating will last longer. I have a 500cca battery for my boat, with a 120aH rating. so you think a 1000cca battery with a 50aH rating would outlast it? CCA usually reflects on the internal resistance of the battery, and how fast it can deliver the juice, the capacity is what deems the longevity of the battery. CCA is the maximum output for the battery, it has absolutely nothing to do with how long the battery will last.actually, if your alternator goes out the battery with more cca will last longest
illusion said:Ok first point, read what he said "I am getting a system soon" well the stock battery and alternator are a hinderance. The battery is the quickest and easiest to replace, but using a batcap you might not even have to replace it, just add a batcap with the amps and everything should be happy, unless you are pulling some serious current, then a full electrical system is in order.
Not trying to be argumentative, but I've been installing for about 15 years, and also happen to have my EE. If you can't back up and argument, please don't try to argue at all.
actually you mislead my comment, i meant that if his car battery is supose to be 10 amp hour (just a number to use) that he should get a battery with more cca it will last longer.illusion said:not true. The battery with the higher aH(amp hour) rating will last longer. I have a 500cca battery for my boat, with a 120aH rating. so you think a 1000cca battery with a 50aH rating would outlast it? CCA usually reflects on the internal resistance of the battery, and how fast it can deliver the juice, the capacity is what deems the longevity of the battery. CCA is the maximum output for the battery, it has absolutely nothing to do with how long the battery will last.
