Try a MILD soap and water soution, but make sure you test this first on a non conspicous spot in case discoloration occurs.
If all goes well, pat dry any excess soap and water solution, then use a vaccum cleaner to suck up any moisture to speed up the drying process. If you don't want to mess up your parent's vaccum cleaner go and "borrow" your sister's hair dryer to dry your Recaro Seat.
Hope this helps.
:spawn:
