K, so, since I purchased the car back in October it's had an idle issue(revving up and down) until it got to operating temp. Guy said it's been doing that since he had purchased it years ago. I thought nothing of it til now. Recently, since about mid december, my car has been pms'ing a LOT. It now continues to have the idle issue and my oil temp gauge goes past the H after driving down the highway for about 15-20mins. So I asked my auto teacher. Said it's either a tight throttle cable, or low on coolant. Filled that sob right up with coolant and the idle problem went away......for about 2mins. As I left my school car started smoking REALLY bad and sounded like it was choking, spittering and sputtering badly. So it's burning antifreeze
So, all this being said we came to one of a few conclusions that either a)head gasket could need to be replaced b)block could be cracked somewhere which is causing pressure to build up and c)I forgot what c was >.<
Anyways, wondering if you guys have ever experienced similar problems or have any other ideas as to what it could be. It's my only car atm and I'm hopin the problem is as cheap as a head gasket but I can only hope. It's a 94 S with a stock D15 in it. Also, plan on replacing the gasket this weekend so any advice/tips on that is appreciated. Thanks <3
