i accidently forgot my log in for my Window Xp...so now evrything is lock out...i can't even boot up for my CD for reinstall new Window...so is there anything i can do for solve this...help me ASAP...thanks
If it is windows xp HOME, will not work for PRO
restart your computer under SAFEMODE. Press F8 or one of those F button and go to safemode
once there you should be able to go into control panel and go to the user account and change it.
Discussion Starter #4
i unable to get in Safe Mode or either Bios setting...they got lock out by password....they both ask me for password ...so head up...help me out..thanks
Okay no idea if this works because i havent need to use it but by reseting your password you will probably lose any recent applications, usergroups and doc you might have saved before. So use this at your own risk and just follow instructions on this site. You might wanna just send the email using ur own email or something.
http://xpcracker.mine.nu/xpcracker/index.htm
Premium Member
you could try at th elogon screen hit alt+ctrl+del 2 times it will then allow you to sign in as admin and usually that password is not assigned from the cactory, if it is its usually administrator depending on who built your comp
