ya think??????
Obviously an obd2 engine comes with completely differant sensors, but what i'm trying to say is: Does the conversion harness render some of the sensors useless? Will the car be throwing obd1 codes correctly if there is a problem? Can you cange the timing without the car automatically recalibrating it? Can you run a header with only the single o2 sensor? If your not currently running or have had personal experience with a similar setup please do not comment. Educated comments are appreciated. Thank you,
