Hi, Ive got 2 intake manifolds here a regular one which came with a b18b1 out of a 96 integra rs. i also however have one from a 93gs which says PGM-FI accross the top. it appears a lot fancier and has capability for a lot more should i switch these manifolds, are there any benefits? also if i have a machine to bore cylinders can i bore out my throttle body and if so where would i finda larger throttle plate?
Stick with what you have unless you have modifications to take advantage of anything.
Unless its an ITR IM, swapping stock ones is pretty much pointless.
Yea,
THe PGM-FI (Programmed Fuel Injection) across the top is probably just Acura/Honda trying to show off their system and making it stand out in 1993 against the earlier cars in the late 80s that were still carburetted.
