pistons for supercharged d16 civic
4229 Views 5 Replies 5 Participants Last post by  ngms72
Alright, I am having to have the engine short block replaced, and I am going to try and get forged pistons and such... I am running a supercharged application and the stock pistons and rings lasted maybe 7500 miles. I need your help!! I don't know anything about this portion of tuning, and am wondering what are the name brands that work with the D series engines and if you could can you send me some links??? I appreciate your help!!!
'97 Honda Civic
A friend of mine has a '97 Civic D16 4dr., and wishes to get some parts for his car...the budget unfortunately is $200 :mad
any help would be great...
Thank you
What's your C/R stock and how much boost are you planning on running on what system? I need more info.
I know exactly where to go...
KMS engine development is where you can get a really good pair of pistons....
Check it out
http://www.honda-performance.com/default.asp:)
How much boost are you running. If 10 and under your stock pistons should of been good enough with a good tune.
agreed... you really only need new piston if your boost is going to be above 10 psi or around...
