Hey guys,
You know when you install an exhaust and the catalytic converter has one end that has two holes that bolts to the header, and the other end of the converter has three bolts in a triangular pattern that bolts to the beginning of the cat-back system? Anyway, can you take those bolts out (the triangular pattern) and replace them with new ones? The bolts are all stripped and messed up from removing the exhaust so many times, I can't even screw a nut onto them. If I take apart the heat shields and check it out, can I like unscrew the old bolts or something and replace them with new ones from the inside? I don't want to try it cause if I remove it one more time, I doubt I'll be able to reattach the exhaust to it, them I'm screwed to hell. If you have any diagrams/info on the converter construction, I'd appreciate it if someone can post it. Thanks...
