For $250
For $250, you get a pocket port, similar to what Honda does to B16 heads to make them Type R heads. Nothing major, but you have to remember, cost doesn't necessarily = Best finished product here.
When you get a head ported, you're virtually making a decision of what type of FINAL set-up you're going to run. Not a thing where you say, oh, well I think I changed my mind, I'm going to lower the compression and go turbo after putting in 12:1 pistons TODA B cams, etc... and get the head ported to the exact cam lift & duration, and compression ratio. Heads are very purpose oriented when it comes to machining them. You have to know that the more you machine off isn't necessarily going to be better. Imagine blowing thru a coffee stirer, then one of those big-diameter McDonalds straws, or the intake off your car. With the way your lungs are, you'll get the best flow through the McDonalds straw. The coffee stirer bottles everything up. You might have high velocity, but try to blow a balloon up through one of those suckers-- you won't fill any volume of the ballon nearly as fast as you would the McDonalds straw. With the intake, you have virtually no velocity or volume filling capacity. So as you can see, contrary to the pontiac grand prix, your you homeboy's ex-girlfriend, wider IS NOT better. Eventhough there's not real good real-life booster you add to your lungs, imagine if your lungs were really powerfull, or even had a mechanical fan hooked up. Then maybe the intake tube would be the better application. So if you're going to do this, do it purposefully.
