Is it necessary to remove the intake manifold from the motor to port match an aftermarket T.B. to it?
I have a brand new in the box STR 68MM T.B. that I'd like to bolt up, however, I don't want to hassle with removing the intake manifold.
Anyone done the port matching without removing the manifold? If so, how do you avoid gettiing shavings into the manifold?
thanks!
