Well i did the foglight conversion using a 1157 bulb socket. I changed my front blinker to where my corner lights are. I did this by running the blinker wire (+) to the corner light. Everything works fine, my bumper lights stay on all the time, and my corner lights now blink when i signal. However, i have the dreaded "hyper blinker" issue. I made the 100K potentiometer from cryogens website to help get my blinkers back to blinking normally, but it didnt help. When i turn the potentiometer dial to lowest setting the blinker still blinks fast as if i never installed the potentiometer, on the highest setting the blinkers blink so fast that it looks as if the blinkers are constantly on. Should i go with a 1M ohm potentiometer or what other options do i have to fix the blinking problem? My corner lights use 168 bulbs which are rated at 7watts(i think) and the original blinkers were rated at 21 or 27watts(7440 socket) i believe.
