So the front driver side power window is almost gone.
It will go down about 1/3 of the way then slow to a crawl and just stop.
It needs a good shove for it to go down and a good pull for it to go up.
I'm going to be ordering a new regulator and motor off ebay in the next few days.
Anyone have any tips on removal and installation?
I tried searching on the net for pictures but didn't really find any that helped.
The Haynes manual isn't that detailed either.
If you have links or tips please share!
Thanks in advance.
Before you tear your door apart..like I did just the other day. Try lubing the guide channels with some Silicon spray (I don't have tinted windows, if you do check to make sure that won't harm the adhesive or film).
Then I lubed the regulator cables and slide. You can get to this with just the panel off.
I put my driver's side back together..then lubed the rest. They all move MUCH FASTER and smoother.
Good luck...
