Power windows
568 Views 5 Replies 3 Participants Last post by  viperredrex
Anyone know if the door equipement from a 90-93 Integra will work with or windows to convert them to power window status?
I am lazy and I have a turbo now so the weight won't bug me as much as it might have before. I want to be able to push buttons not turn handles. I have already figured out the way to do the window switches so don't say but you won't have any switches. Just need to know if the Integra window stuff fits the CRX/Civic door. Thanks!
why not get the JDM EF7/8 PW stuff?
well, I made some 90 prelude si p/w work. hell integra stuff would probably be pretty easy as well.... the bolt pattern is already in the door, you just have to make a cut out so the motor will fit. I had to change the main slider bar that bolts to the bottom of the window. took a total of maybe 6 hrs, with wiring !
Good luck
Adam
Good luck
Adam
Doesn't sound too bad and I saw that the holes where there already I have access to frree Integra doors if I want them so I was thinking about getting the power window shits out of them. The hole you cut for the motor was that with a metal cutting wheel or what?
I can get the Integra stuff fro free. But if it is a problem then I'll get the JDM stuff. Trust me I thought of taht already. Plus I'm trying to get the window switch parts form a guy in the Netherlands right now since the controls will be on the right side of the car.
i'm a car stereo installer so i have quite a few resources on hand, however a dremel with a high speed steel bit would work great, as there isn't much that needs to be cut!
Adam
