mike_sho, i tried to put the name of the forum where i found the video from because there they say who the owner of the car was and what mods he had. Let me then put the mod list here then since the forum name is blocked here.
Modifications
ENGINE:
- AEM Modified Cold Air Intake (B18C5) with Custom AirBox
- NGK Multi Power Spark Plugs
- Thermal RD 3" Cat-back Exhaust with 4" Tip
- CarSound 3" High-Flow Catalytic Converter
- HyTech 304 Stainless Tri-Y Header with 2.5" Collector
- HyTech Tapered 2.5" --> 3" Stainless Flex Steel
- B&M Fuel Flow Modifier
- B&M Fuel Pressure Gauge
- 3" Test pipe (Track only)
- PYR Overbored Throttlebody (64mm)
- PYR Race head:
(Race P&P, 5-angle valve job, Welded Chamber, Milled, Blueprinted)
- Type-R intake Manifold modified to Fit B18C1 Head
(Intake Ports are slightly larger than the Intake Manifold)
- Crower Titanium Retainers
- TODA Racing Dual Valve Springs
- TODA Racing Spec B Camshafts
- TODA Racing 2nd Generation Cam Gears
(10 oz.each)
- Power Enterprise Super Strong Timing Belt
- ENDYN Rollerwave NA Pistons
(0.5mm Oversized, 12.2:1 CR)
(Rollerwave Combustion Theory)
- High Compression NA Piston Rings
- Eagle Connecting Rods
- Modified Intake Slash Tube
- ARP 2000 Rod bolts
- Honed and Rebore to1825cc
- Bottom-end Fully Rebuilt by Leitner&Bush
(Balanced and Blueprinted)
- RC Engineering 310cc/min Sat. Fuel Injectors
- Walbro GSS317 In-tank Fuel Pump
- MSD 6AL Ignition Control Box
- MSD High Vibration Blaster Coil
- MSD Modified Distributor Cap
(With Drilled Vent Holes)
- MSD 9000-Series RPM Module Kit
- MSD 8.5mm Super Conductor Plug Wires
- MSD Launch Control Module Selector
(With Custom Indicator Lamps and Switches)
- J&S Electronics Ultra Safeguard V.1Knock Control
- J&S Electronics 2-Way Dual Monitor
- APEXi PowerFC Stand-alone EMS
- APEXi FC Commander Pad
- Godspeed MotorSports Adapter Harness
- Fluidyne 40mm Racing Radiator
Fluidyne High Pressure Cap
- Fluidyne Ultra-Thin Hi-Cooling Radiator Fan
- Fluidyne Ultra-Thin Hi-Cooling Condensor Fan
- '00 Integra Type-R Transmission with LSD
- ClutchMasters Stage III Clutch
- ClutchMasters 8-lb CNC Aluminum Flywheel
- Integra Type-R Gauge Cluster (Canadian Spec)
- Autometer Black Face AFR Gauge
- Autometer Ultra-LIte Mechanical Oil Pressure Gauge
- Autometer Dual 2" Gauge Pod
- Energy Suspension Polyurethane Motor Mount Inserts
- Energy Suspension Shifter Stabilizer Bushings
- Shortened Stock Shifter
Also a link where they got this info from:
http://www.geocities.com/leunghomepage/ModsIntegra.html
