My p28 ECU was fried a month ago (don't know what happened to it) So I replaced it with v-tec compatible p07. It ran great with no issues after I re-chipped it.
The problem was when I went out for a joy ride. I hit higher RPMs and the CEL came on. I used the paper clip method and it showed a bad ecu (none blinking cel light)
Now my car will not stay on unless it feed it gas. I'm certain that I don't have a short, but I have had bad luck with ECU's. What can be causing my ecu's to take a dump. Will Hondata be a better route to take??
By the way I am tuned for more fuel and N2O system.
Thanks and any help will be appreciated.
found short
dude ive got a f-22 that was giving me the same issue and come to find out that it was simply a bad ground that went through the firewall.i fried 4 ecu's before i found it.
