For a '93 civic ex what turbo would be best. Any advice would be appreciated.
what do you want to do with it? a quick street car, drag car?
Discussion Starter #4
i am wanting it to be a street car but i dont know if i should go big so its faster or go a little smaller so it spools up quicker.
well you can get a turbo that is in the middle, I would recomend a t3 45 or 60mm trim the 45 trim is good for 250hp and the 60 trim is good for 300 hp just use a standard size turbine and .48 a/r, and youll be set, If you dont want to custom order one, you can look for a turbo off of a 88-89 ford thunderbird turbo coupe, if you can find one in good condition, that would be a excellent starter turbo. you can usually find one for under $150.00 from someone in this forum, or in a junk yard for about the same price however you may have to rebuild it.
good luck
Laters...
[email protected]
