Carefull...
My experience with projectors has sucked so far. I have a 00’ civic… So my lights should be close to what you are going to get. First, they DO leek! Put some sealant all around, weather you see leeks or not! And the beams ARE way out of alignment! Here is the key to this problem: there are three screws on the back to adjust the projector, and there are two to adjust the high beam. Go to a parking garage or something, take bumper off, install the new lights, (no new wires are required, it has the same plug) don’t bolt the lights on until you align them. First look where your stock lights are pointing. Use some chalk to mark the spot on the wall of the garage. Adjust the new lights to point at your mark. BE CAREFULL!!! Adjust the beam using ALL the screws on the back, little by little. Spend an hour if you have to, when it feels like the screw is getting tight, STOP turning it. There are these little plastic tabs that the screw goes through inside if you pull the tab to much it will pop out and you are never going to be able to adjust that thing again! Also, look at the projector lens itself as you adjust, you don’t want to get it into some strange position. I did everything wrong, so I know how it works now. I had to take the whole thing apart to fix it, because it leaked and the beam was all crazy… so I opened the light and fixed it, and then the damn thing broke again! I still put up with it, because those lights look awesome. Just seal it, and be careful, you should have no problems if you take your time.
