i have everything i need so i can play ps2 on-line, but i get an error message during setup. i'm trying to set it up using a braodband connection, but i always get "DNAS ERROR (-881). PLEASE HELP ME!!!!!!!
I'd say call the hotline.luckylou07 said:i have everything i need so i can play ps2 on-line, but i get an error message during setup. i'm trying to set it up using a braodband connection, but i always get "DNAS ERROR (-881). PLEASE HELP ME!!!!!!!
what are you trying to say? that i'm a dummy and don't know what i'm doinggreenmachine2k said:Sounds like user error. Try turning the PS2 on or plugging the cable into the wall.
i have a cable modem. i also have a router. so right now my cable modem is connect to the router and the cable connected to the ps2 is connected to the router. i woudl connect to the cable modem but it didn't come with any extra ports. i have 3 ports left on the router so i put the cable in there. i unplugged the cable thats connected to the cable modem and put the cable hooked up to the ps2 in there. when i did that it said the it couldn't connect to the dnas server.crazed87 said:what kind of connection are you on?
cable or dsl?
did you plug the cable into the modem? or the wall?
i tried that and it said it couldn't connect to teh dnas serverinfox said:have you even tried to plug the ps2 straight in the cable modem then turn the modem off/on? That would narrow down what the issue is
i tried that and it said it couldn't connect to the dnas serverinfox said:have you even tried to plug the ps2 straight in the cable modem then turn the modem off/on? That would narrow down what the issue is
Obviously, if you are having problems with your ps2 network connectionluckylou07 said:what are you trying to say? that i'm a dummy and don't know what i'm doing
You lost meluckylou07 said:i have a cable modem. i also have a router. so right now my cable modem is connect to the router and the cable connected to the ps2 is connected to the router. i woudl connect to the cable modem but it didn't come with any extra ports. i have 3 ports left on the router so i put the cable in there. i unplugged the cable thats connected to the cable modem and put the cable hooked up to the ps2 in there. when i did that it said the it couldn't connect to the dnas server.
J30A1Accord said:Obviously, if you are having problems with your ps2 network connection
i've tried setting it up with madden 2005 but still got the dnas error. greenmachine2k is my friend so i put that dummy response as a joke.
