1 - 8 of 8 Posts
I had an a quafe lsd put into my turbo civic, but never phisically saw the unit.Call me a suspicous sob but is there any way to tell if its in there or not? I i raise the wheels of the ground and turn one tire if they both turn in the same direction that means it is an lsd. no?
yes.
if it was a standard diff, then one wheel would turn one way and the other the opposite way.
another (more fun) way to check is to smash the gas and burn out.
then check the tire marks. they should be equal length on both sides.
if not, then the lsd is bad, or you got ripped, but it sounds like you already checked the first way so you're good.
no worries! :)
Discussion Starter · #5 ·
I did do the burnout test and was rewarded with two black marks of equal length. The only reason why this wasntm good enough for me is because i have seen several hondas with open diffs leave two marks.
1 - 8 of 8 Posts
