how do u adjust them ???
i know its a newbie question and prob ask b4
but since the board was down and everything was erased
i couldnt used search
Premium Member
For height you loosen the screw perch and either screw the collar up or down depending if you want to raise or lower the car and then reset the setscrews. Before you reset the screws, measure all four corners to determine if you get it correctly done, then reset once you're satisfied.
If you mean the shocks, they have a knob on the shockbody to adjust the dapening. The higher the number the "stiffer" the setting.
Hope that helps!
i know about the shocks i just wanted to know about the coilovers i was confused on how to adjust the height and knowin how low or high it would be
