At the moment my car is getting painted, and I have a Black Widow rear bumper for it.... I was planning on getting a Apexi N1 Cat Back but it says that it projects on an angle so that wouldn't work well with my rear bumper... Has anyone ever seen this done? Or you guys with the BW rear bumpers what kind of exhaust do you guys have?
A lot of people just do custom exhausts.
I'm sure if if you decided to go with that exhaust system you could just have the part of the axel-back pipe that angles the muffler cut off and get a straight section of pipe welded in its place.
if the search is workin try that because ive seen this problem with the BW kit many, many times. Most pepole just end up goin with a custom setup and its usually cheaper.
Simple... have them bend some exhaust pipe and if need be add extended hangers from the exhaust and the problem is solved.
