I'm totaly new to honda's, but need something that gets good mileage for cheap.
I can't find a 'VX' car anywhere, but there's a 95 Del Sol S & a 93 Coupe DX that both need engines for sale in the paper.
If I get a 92-95 VX engine (D15Z1) also called a vtec-E I think, will it drop into either of the above cars with no rigging things? Do they use the same fuel system and computer etc.
If I have to cut & slice electronics & fuel system things, I probably wouldn't do it. I don't have alot of diagnosing experience.
Thanks for any help or links to subject. :D
as long as they r Vtec models cause the ECU controls when Vtec is activated and the VX motor has to have its ECu or it wont work.. so get it.. drop it in, add the 2 wires for Vtec and b on ur way to good gas mielage, PM me if u need any help...
Discussion Starter · #5 ·
hum, these are standard models, how hard is it to swap ECM's? '92-95 is OBD-1. Is that the name of the ECM? So a D15z1 is a small, high efficiency ***** engine? ***** is something that advances the cam?
3 wires for vtec :)
why not try to find a d16y5 engine (96-00 civic hx)
