Can I just put on the flywheel if it has surface rust on the part where the clutch disk hits the flywheel? Also, does the pilot bearing go on the flywheel? When i look at the manual it just says "flywheel bearing" When replacing the throwout bearing, do i have to use molybdenum disulfide? Or can i just use regular grease from a grease gun? Or would silicon grease be fine? Thanks
Ulti-
