alright so after looking at it and playing with the throttle heres what i've found out
when first started it idles almost normal at like 500-600 rpm. Then when you give it some gas it doesn't hesitate much and it revs fine. Then when you let off it drops down real low almost to the point of dying. Then when you give it gas it hesitates for almost half a sec before responding and after that its fine. I can also smell it running quite rich, though its gotten a little cooler here so that might be the cause of that.
i reset the ecu and checked the plugs. The plugs look a little lean.
heres what i was thinking: it needs some fuel system cleaner run through it, check the 02 sensor, the iac might have a clogged screen?
anyone have any suggestions?
