QuickAirX air compressor is a great track side tool!
Attention Track DieHards!
All of you guys that like to have an air supply on deck.
This is the compressor for you, small and lightweight, easy to use.
Air up tires or even run some air tools if you hook this compressor to a small tank.
Sun Performance is releasing their new line of compressors, the QuickAir X, which is due to release in April. These compressors will be of higher quality and faster than their previous QuickAir's. We currently have two models available and come in a hardmount or portable version:
QuickAir X 1500
- 12-Volt
- Permanent Magnetic Motor
- Amp Draw: 20 Amps
- Duty Cycle: 100% @ 100 PSI
- Max Working Pressure: 150 PSI
- Min. Ambient Temperature: -40 degrees F
- Max. Ambient Temperature: 160.6 degrees F
- Dimensions: 257L x 100W x 163H
- Net Weight: 7.72 lbs.
- Time to fill 2.5 Gallon Tank: 0-100 psi - 2 min 30 sec.
QuickAir X 2000
- 12-Volt
- Amp Draw: 22 Amps
- Max Working Pressure: 200 PSI
- Max. Ambient Temperature: 142.2 degrees F
- Dimensions: 288.5L x 100W x 163H
- Net Weight: 9.26 lbs.
- Time to fill 5 Gallon Tank: 0-200 psi - 11 min 15 sec.
PM for more information!
QuickAir X 1500
- 12-Volt
- Amp Draw: 20 Amps
QuickAir X 2000
- 12-Volt
- Amp Draw: 22 Amps
