Beg to differ...I can feel the rear of the V powering through the turns (even on dry roads) AS LONG AS I KEEP ON THE GAS. :byeI's going to feel the same, .
that's trueAs long as you like it, Chris, I don't think it matters if it's there or not.
Id assume better mileage because thats less drivetrain loss. I think thats why Honda used live 4wd in the first place, fwd until it sees the need for extra toruqe via locking in the rear wheels. Not too sure, as I didnt doublecheck.I'd assume it'd be worse mileage, since that shaft only works out when the wheels go... Leaving it off may not be a bad idea, but dif back there may not like it. I'm not sure. Still want an electric selector, and I'm sure it's possible to convince the car it's slipping all the time, but the Diff may not be able to support itself doing that.
That's true... but the drivetrain isn't under a lot of resistance since it's not connected to the axles until a slip, so it may make a difference, but the way you put it, it probably would get better mileage.Id assume better mileage because thats less drivetrain loss.
