1 - 14 of 14 Posts
i need help on my "91" EF civic hatch Si..... I'm trying to do a rear conversion and im getting mixed answer's ???? i heard that i can use "REAR TRAILING ARMS from 93 INTEGRA with CALIPERS & ROTORS ATTACHED" BUT i do not need the upper or lower control arms ...-- i don't get that??? i thought i would need them actually..... ok..... and the next thing is... can i use something else like rear suspension from a 2000 civic Si or from a "94- "00" gsr???
do i only have the 93 integra rear ??? i hope these aren't stupid questions...... im just really confused...
OK ... what i think is yeah... i can use the other suspension set-ups i've mentioned...... but what parts am i goin to need ??? the same as the 93 integra like i said before or more then that....
thank you ..... :confused:
yoo..... what the &$%^.. are people to lazt to help me over here ????
dude dont take it personally if you dont get any replys to your questions. it might be because no one really knows or some people might know something but dont want to give u misleading info.
as for your brake question the disks from a 90 or 91 crx si might work, but then again i'm not sure so i dont want to confuse u.
Discussion Starter #5
man don't give me that........ i know people know in here.... someone out of how many people must know.... even the moderator should know this........... people just don't want to help and thats foul... or they don't open some threads....
Discussion Starter #7
it's koo with me..... i have other questions to ask.......i can find out the answer to this question by other means.......p-ce
do a search for my name in the civic forum, I started a large thread about rear disc conversions
Hey crying ass!!!!
You can use any of those. I'm not sure why nobody knows that. Anyways you just need the trailing arm with the brake shit attached and the e-brake cables from a car other than a CRX with rear discs they are to short. And possibly then soft brake line might be shorter I don't know I just ordered a Goodrige brake line kit for a CRX with rear disc and used 90 LS Front and rear brakes and M/C and B/B and proportioning valve. Basically every peice is now integra and it all bolts up except the front ones if you don't have the b-series size axles. Hope this helps!
as far as i know, you need trailing arms, hubs, rotors, calipers, lines, pads, and e-brake cables. . . might not be a complete list but this is off the top of my head. . . i know del sol lines come up rather short though
brake booster is unnecessary
I am the moderator.....and I have no clue how to answer your question. I have not performed a disc to drum install on a civic...in fact I haven't worked on civic's at all....just rsx's, prelude's, and some integ's.
1 - 14 of 14 Posts
