After getting the tranny and flywheel/flexplate off, is replacing a rear main seal on a y8 pretty cut and dry? Pry it out and tap the new one in with a 2x4?
Also is it ill advised to start the engine with the flywheel off to make sure it is sealed well? Probably is... would idle really rough, but it's a lot of work to torque the bolts on the FW back on only to take it off if the seal is still leaking or not in far enough
