My suspension is currently stock on my 2000 Si and I'd like to spend about a hundred bucks on something to spice it up. . . and I was thinking a rear strut bar would fit the bill (since it's already got the front one), but in surfing through the forums I hear that it won't give a very noticeable difference unless I've done other suspension modifications. Should I go with my plan or should I start somewhere else with my suspension?
And while I'm at it what rear strut bar would you reccomend around my price?
Thanks!
I would suggest a rear tie bar or a front lower tie bar. I have both the rear is cheapo megan racing and the front is a Tanabe Sustec both make a difference in handling. The lower ties are cheap (mine was 35 dollars) and the front brace is a lil more (mine was about 100 bucks shipped) but I think the front make a bigger difference.
Discussion Starter #5
Well I guess that seals the deal. . . I'll save up for a good spring/strut combo first.
Thanks!
Craig
Premium Member
kommon_sense said:
shocks and springs first, then sways, then rear lower tie. Wouldn't really bother with the rear upper strut bar on a street car, especially if you use your trunk.
:nod
That's the reason I took mine off. Makes me really miss having a HB...
Slicing through the interior lining bothered me not in the least.
Super Ban-Finger Mod
since most hondas have inherant understeer from the FF layout, i'd stiffen the rear up more than the front for more neutral handling. like everyone said, start out w/ a good spring/strut combo, then a thick rear non-adjustable swaybar, or front and rear adjustable swaybars adjusted for oversteer mode. if you're on a budget, skip the front strut tower bar and just tie up the back.
