My car is really rusting out in the rear wheel well. I know its a common problem on the 94/95 accords. I found replacement patch panels online for ~$40 each. See: http://tinyurl.com/cmhafh
How difficult this would be for a DIY fix? I would have to get it welded at a shop, because I don't have the welding equipment.
I was reading about 3M's Automix to basically glue patch panels instead of welding. What do you guys think about using that stuff vs welding?
Here is what I was thinking about the 3M Automix: I would trace out the patch on my car and cut out the sheet metal about 0.5 to 1 inch below my original line. I would make a flange so it would be indented on the original sheet metal up to the line I drew. The new patch would then lay in the flange and line up with the original sheet metal.
Does anyone have suggestions, or has anyone attempted fixing this problem on their own?
