It's easy. Just get a heat gun to loosen the glue holding the badge on. Then use something like a plastic wallpaper scraper to gently pry it off. Just be careful not to melt the scraper and avoid using something metal to scrap off the badge as it will easily scratch the paint. When it's off, you can rub off some of the excess glue off with your finger. The rest will come off with rubbing alcohol.
