1 - 10 of 10 Posts
anyone know how to remove the actual key lock from an EK door? I need to swap the locks with the new doors im putting in and cant figure it out.
i would think you'd be able to tell kinda if you got to it from inside the door panel. if not then you may need "special" tools of some sort
i have the panel off, but i cant access it because the shell part is welded on.
shell part? in my EG i took out the manual ones to put in automatic ones...it's pretty simple. there's 3 screws in the door jam where the door locks to the body and then there's 4 connecting rods, 2 to the outside door handle and 2 to the inside door handle. As for taking those off, the two to the inside door handle should pop off at the actuator/lock and the two to the outside door handle should pop off too or at least unclip. One of them can be poped off then you have to unscrew the piece that is left on the rod and put it on the new lock...just remember how many times you turn it.
Hope this helps.
Discussion Starter #5
not the whole assembly, just the part that the key goes in. the actual lock just needs swapped.
Discussion Starter #7
how do you get the handle out?
1 - 10 of 10 Posts
