i have an 92 CXand i been trying to remove the lower control arm from the ball joint for the past week. I been working it for like 2 hour everday trying to remove the arm. I try hitting it with a hammer and i even went out and got a ball joint separator. i even took out bolt that hold one part of the control arm to the car. Am i doing something wrong b.c it would not come out. i need some advice.
- put jack under control arm
- jack arm up
- place large metal bar between knuckle and lca
- lower control arm
the suspension will force the lca back down, pinching the metal bar and it will pop/seperate the ball joint all on its own with no damage to the joint or the boot.
