1 - 12 of 12 Posts
I'm replacing the cv shafts on a 96 honda, but I can't get the lower ball joint out of the knuckle. I've tried hitting on the control arm, but it's not coming out. Any help would be much appreciated. Is there a special tool used?
Discussion Starter · #5 ·
Thanks for the help. If i go with the ratchet, where would I place it to seperate the ball joint from the knuckle. Sorry I'm new at this but I can't picture how to use it.
Listen, I almost gave up on that too with the hammer. My suggestion is get some Liquid Wrench and soak it down. Let it sit for about 15-20 minutes, then start banging away again on that ball joint. At first when I did it I was timid and not hitting it hard enough thinking that I would break it. However, think about how much weight is on that joint and then get medevil with it...
Let us know...
Did you crack the ball joint boot? If so did you replace the ball joint and check all threads before you re-torqued to spec? Ball joints are easy but looking at people stuck on the side of the road from a lower ball joint failure isn't a laughing matter. If a ball joint goes out you can be in some serious shit bro.
watch the video, you can see where the ratchet is right when the jack drops. it has to be a box end though.
if the ball joint separator you got is the pickle fork kind, those things tear up ball joints like crazy.
You are a genius. Happy to have stumbled on this via Google, 3 years later no less ..
I spent a couple hours spraying PB blaster, beating the crap out of the control arm, jacking it up, and for the life of me I couldn't find leverage or break lose my right ball joint -- it is the original on an '84 civic 1500s, so no surprise there - It was a nightmare getting the axle nut off on the same side as well.
It was a tight fit with the 1/2 ratchet handle, but worked like a charm without tearing up the boot and had it off in about 2 minutes.
You are a flocking genius!
:clappy
1 - 12 of 12 Posts
