why do u need to take it off? and that cap is actually hydraulically pressed on. i dont think you can pry it off, but behind it, theres should be 4 bolts holding the hub on, take it off, and the hub will come off.
**EDIT*** ok umm i just checked some thing out, and it can come out, but you will need to rather have 2 good flat heads that fit in it and pry it out at same time, but not fully, just pry each side equally with 2 on the opposite sides. You will neeed to pound it in to get in between. u can use a flat chisel.
Heating it up a bit will help it, but do not get it tooo hot though.
thanx bro, ... on wed when i get my new discs, i'll be doing the 5 stud conversion. and i was jsut lookin at it yesterday and couldnt' get it off. guess i didnt try hard enough.
thanx for that.
