Is it possible to reset the chip to factory settings? If so, Is it possible to tamper with settings on the chip?
Scenario:
Check engine light comes on, its possible to turn it off by pressing key back in the gauge cluster hole. By resetting this, you clear the light of the check engine, but the chip keeps it in memory and if you take it to Honda, they can clear the check engine off of the chip.
What does Honda do? Do they replug the the chip in their own computer and reloads settings of model?
[computer chip - - - plugs into Honda computer program]
[computer program resets chip and changes setting to zero]
[computer program loads model settings into chip]
If this is what they do, does this mean that the settings on the other fields such as rpm redline, temp... are also changeable?
Scenario:
