I have a stock 91 ls with 191xxx miles....im goin to adjust my timing ans wandering when its set and i reset the ecu and run the car hard will the ecu respond as its gotten faster i dont understand the whole ecu restting think plz help...
You don't always have to reset your ecu when you make changes to your setup. Some cars will adjust real quick and others will adjust to them quicker when you reset your ecu. Typically you reset your ECU because you have a troble code and you have fixed the probelm. I wouldn't reset it when you change your timing unless you are really bored.
