1 - 10 of 10 Posts
I'm building an ls/vtec, i got the crank balanced, eagle 4340 steel
rods, 1st gen b16a pistons, vtec oil and water pumps. My
question is what should my rev limit be? I'm also using a stock
1st gen b16a head. Also what is the rev limit of the 1st gen
b16a "PW0". JayMan320 I know you know dude hook me up man.
8000rpm, you wont make much more power past that.
let me know how you like it, i've been researching it for a while and doing the conversion with a fully built up skunk2 stage 2 gsr p/p head.
good luck
ryanplayjoint said:
. Also what is the rev limit of the 1st gen b16a "PW0". JayMan320 I know you know dude hook me up man.
89-91 (PWO)
88-91 Si
88-91 CRX Si
-Redline: 7100 rpm
88-91 Si 16-1.6i
88-91 CRX Si16-1.6i
(Asian specs)
-Redline: 7200 rpm
90-91 Civic Si-R (EF-9)
90-91 CRX Si-R (EF-8/9)
-Redline: 8200 rpm
ryanplayjoint said:
My question is what should my rev limit be?
75-8k should be your limit.
Discussion Starter · #6 ·
I'm hearing from alot of guys that my b16a tranny is not strong
enough for 180-200whp numbers. Which would be a better
setup? A LS tranny or a GSR? Also i have a question that hasn't
been addressed in the furom of ls/vtec's. Wjat is a good boost
level on the ls/vtec with the stock sleeves?
8-10 daily driver...c/r 10:1 and lower...
The B16 can hold, Where did you find that misinfo? A Friend has a b20/vtec making well over 200hp, no tranny problems so far.
LS=longer gear ratios, suited for a FI car
GS-R=1st-2nd same as LS...3rd and up gear ratios become closer.
Honda Gear ratios
Discussion Starter · #9 ·
Will my 1st Gen B16 pistons be a bolt in process? I read that the
piston might have to be shaved ? What part of the piston needs
to be shaved if nessesery? Also is my 91 dx fuel pump combined
with the b16 injectors and a fuel presure regulator enough for
the 170-180 WHP i hope to fuel? Thanks you honda freaks
1 - 10 of 10 Posts
