I put a set of used tires on my 17's, they're in good shape but there's quite a bit of road noise(humming, especially when slowing down) :speaker: It's been like 10 years since i've had aftermarket wheels on a car I drive daily, so I can't really remember if it's normal or not(geez, i sound old). They're kuhmo tires with about 90% tread left. I do plan on getting brand new tires when the funds become available. What do you guys think? Is it just a bad set of tires or is this normal? Any comments would be appreciated.
Thanks
Drive them for a bit until the tread on all the tires is even from the inside to the outside of the tires (or as even as they'll get with whatever OEM toe/camber is present). It could just be that they were previously mounted at different corners. My Yokohama summers definitely give more road noise than my all seasons.
You sure it's tire noise during deceleration? Does the steering wheel shake at all?
definitely tire noise, i always hear em, just more prominent during decel. and yes they were originally the dudes rear tires. no my front two tires are not worn out though. i did notice by the wear pattern of his front two tires (which is now my rear tires) he had serious neg camber issues, i have a slight(normal) amount of neg camber but this dudes must have been awful. his rear tires were almost perfect but his front had pretty heavy wear on the far inside of the tire which is why i put them in the rear. don't have any shaking though, smooth just noisy. thanks guys, you know how it goes, hearing an outside opinion helps open the mind to other possibilities.
Discussion Starter · #6 ·
:surrender directional and yes mounted correctly. prob just the tire, i'll keep the radio on blast when i drive :taco til i upgrade shoes. Thanks guys
yeah, then the only thing it could be is the way their worn. if its not noticable visually, then rub your hand down and around the tires tread and you should be able to feel it.
Some tires are just plain noisier than others. It has to do with the construction and materials. That is part of the reason why the high end tires are more quiet. My Hankook make a lot more noise than my Nitto's did, but they handle a lot better so it balances out in my mind.
Discussion Starter · #9 ·
thanks
well, what would you guys recommend? which brand is gonna give the best grip with less noise? so i know what i should get. i'd trust you guys word over the tire sellsman because of course they're gonna throw the most expensive one at me :kick
