when installing new rod bolts, do the bolts need to be pressed into the rods by a machine shop? or can i install the bolts by pushing them through partway then tightening them down with nuts?
If you use arp rod bolts, you can tap out the stock bolts, and insert the new ones. You then put the cap on, and TQ them as if they were on the crank. that will seat the bolt in the rod. Then you pull the nuts off, remove the cap, and put them in the motor
