JOEL2112 said:
COOL!!!!!!!! so the CL and accord have the same bolt pattern?
Yes
I has the same bolt pattern, 4x114,3
aren't those rotors larger than the stock ones?
I depends on what setup you had before.
I used to have 260mm diameter rotors before and I upgraded them using the 282mm rotors ad calipers from a Accord wagon.
Also Accord coupè and V6 have the same setup.
If you are going to do the hub conversion and you have the 260mm rotors, you can use also Prelude H22, ITR, Nsx, etc... from any Honda/Acura that comes with 282mm rotors.
I don't think it's hard to find them in a junk yard.
any problems with the axle nut since there is a different layout now?
No, I used a Accord nut.
Does anyone see any problems this may cause? if not I wanna do this conversion too!
I don't see problems, as you can see from the pics I did, it's fairly simple, and if you have 260mm rotors, you also upgrade your braking sistem!
