i have a question about this. Could us some help. I have a 2000EK D1Y7A. When i start my car it revs at about 2100rpm.Thats all the time. then every once and a while when i am driving and i put it into neutral or come to a stop it will drop to a really low like 200rpm. Then it will come back up to 900rpm after it sits for a bit.
Don't bypass the iacv. Clean it as described in the forum stickies/faqs and keep moving. Your engine will rev higher on initial startup on cold days. After a few minutes, it should idle normally. As for the rpms dropping really low, that could be any number of things... Bad/worn grounds... bad/worn plugs, distributor cap or rotor... Check out those items.
