What is the max rpm I can spin on a D16z6 with stock internals? It has an 3" intake, and dc sports 4-2-1 header, and 2 1/4 the rest of the way to a carbon muffler, no cats or resonators. I want to buy a chip to "unleash" my bolt ons, but I want to know what a resonable limiter is.
just cause the cam can make powe that high doesn't mean you should rev that high. the parts in the stock motor are designed to work with what its set at and maybe some more. but if you want to get to that high of an rpm, you need to get valves, valve springs & retainers. how many miles are on the motor? if there is alot you may want to look into doing a fair about of rebuild with some stronger after market parts to make sure that nothing on the motor will break while your up that high.
stay away from those ebay chips.
with your setup i woudnt rev past 7000rpm.
