1 - 18 of 18 Posts
Discussion Starter · #2 ·
im getting this code when i looke it up
0102 unknown error - literally means the console does not know what is wrong. Possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
this thread blows..
Discussion Starter · #9 ·
damn you bruce, and fuck you jesus.
if you didnt know, jesus red ringed 2 days after me. the towel trick worked for him though.
me. 2 times at 20 minutes, and 1 time at 1 hour have yet to solve my problems.
wrap a towel around it, turn it on, let it run for 20 mins, turn it back off
let it cool down then turn it back on
towel trick is a no no. dpoes more damage then good. sure it might work for the time being, but you now put the other components on the b oard at a very high risk.
do the towel trick and consider your XBOX even more of a paper weight
Only way to fix this if its the typical RROD is to tear it apart, remove the gay microsoft X-clamps, and replace with rubber washers, new bolts, and nuts. I spent 8 bucks on 8 bolts, 8 nuts, 8 rubber washers, and a tube of thermal grease
1 - 18 of 18 Posts
