1 - 13 of 13 Posts
AlTrOnX said:
hey guys, besides hp and speed what else is the difference between the rsx type s and the regular rsx. is it possible to fix up my regular rsx to the standards of a type s? thanks.
Not unless you do a motor swap. Im sure you can find 40hp from your k20a3 (with a lot of work), but you can not make it equal a type s motor.
Other then that, the suspension is pretty much the same. The type s has sway bars from factory.
Not for the difference in price. When you are getting into 40 HP gains you are getting into the cost of around $100-$125 per hp. And that just gets you to the TypeS starting point.
I don't think that would make as much of a difference on a base motor. The K20A3 doesn't breath too well about 6000rpm, but makes damn good tq with the hondata flash. So, the longer gears might actually be better.
Now, if you did a motor swap you would need the tranny, but most motors come with a tranny and ecu anyway.
1 - 13 of 13 Posts
