So here's the deal. Currently, i'm have an S2000 2005 AP2 gauge cluster for my EK9. I paired the conversion with the AIOS converter module from S2000cluster.com. After following some instructions from the S2000cluster.com about how to set up the fuel, speed, temp and such, the only thing i managed to do correctly is setting the Temperature Gauge Type to 21 segment. The rest i have no fucking clue which correct numbers to set to. Speed and Fuel remains uncorrected. My speed reading is reading @134 MPH during keys in ignition II position and after crank it's at fluctuates between 3-4. Temperature gauge is reading all the way to HOT! While fuel gauge is reading off by 9 bars. Bare in mind, i did not have an empty tank while playing with the numbers like he instruction recommended. If anybody knows how to set the gauge properly with the proper numbers in your S2000 cluster AP2 using the AIOS converter module, let me know
