second gen jdm b16a into EK..questions?
the auto tranny on my 99 hatch finally croaked, so instead of getting a rebuild...i decided to swap in a b series with a manual tranny...I'm familiar with what i need for the tranny conversion, i.e.: clutch,brake, and gas pedal assembly, clutch master cylinder, clutch slave cylinder, and all the hydro lines, but i'm not soure on what i need for the actual motor swap?
the new motor is a second gen jdm b16, the package i'm getting with the motor includes the tranny, ecu, and shift linkage
what i'm not getting: axles, mounts.
what type of axles do i need to pick up?...
which mounts do i need? or will my stock EK mounts work?
what wire harness do i need? or will the stock EK harness work?
what else do i need?
any insight would be great..thanks
94-01 integra axles
94-01 integra tranny mount and rear mount/bracket
If you have vtec right now the harness should work, if not its easy to wire up
