this might be a dumb or already covered question, but bear with me, im just wondering what would be some good susp. mods for a h22 in a 92 HB.thanks.
full coilovers, good tires, sway bars for starters.....
what do you think about some integra springs, you can use them on your civic right?
The first step is always to get good tires.
The teg springs are usually a little stiffer than stock civic springs. A better way to solve the problem would be to get coilover sleeves with custom spring rates.
I would also think that the additional weight of the h22 would cause quite a bit of understeer, so you will need a good sized rear sway. Probably a 19mm unit. You may also need a good sized sway on the front as well. You can get oem bars at 22mm, and most aftermarket bars are 26mm.
