After running my turbo for a while I noticed I had a leak on my oil feed line. I took my turbo off and started inspecting it to make sure everything is ok. While checking the shaft I felt no movement back and forth, but if I applied a fair amout of pressure side to side it would slightly rub on the side. Im not sure if this is normal so I just wanted to make sure it was alright
thanks
