So This is my first time working on a K20z1 Transmission and i was able to take apart the transmission to the point where you can see counter shaft and main shaft, i was checking them to see if they were fine because the engine was recently blew up from a miss shift, i was check the counter and main shaft to see if there were alright and they were, so after i got done checking, i put everything back together, when i finally put the transmission case over and closed it, i tried putting the shift selector/Shift Lever back into the hole it's suppose to be in, and i can't put it in because the shift fork was in the way, so i took of the case to see if i can move it by shift the gear into place which kinda work but as soon as i put the case base on they would lock right back into place to get stuck into the same place so i can't put the shift selector, shift lever.
Please if anyone knows what im doing wrong, i would gladly accept advice. Thank you.
